I searched and couldn't find the answer, so I will ask some of you with more experience. I know how to give an entire cue a higher priority. But I can't figure out how to give particular parameters within a cue higher priorities. Is there a way to do this? IE position in cue 1 is higher priority and will not change position when cue 2 is activated. But other parameters will change according to whats programmed in cue 2. etc etc. Thank you for taking the time to read and answer if possible.
