Version 3.5.0 Full Boar 4
2 Fixtures with the same fixture numbers
1st set are LED units, 2nd set are Mac 700.
When you select fixture 701 for example you get the LED unit, click fixture and change to the 700's, then select 701, it correctly selects the mac 700 in the command line, but the options are still for the LED unit, ie intensity is showing rgb info and you can not select any control commands.
Also have seen the cue list not properly change cues after a goto command, still shows the old cues is running and it does not go to the correct cue in the cue list till play is made for the next cues. Cue OUTPUT is correct, it's only on the cue list itself.
Also seen command lights get stuck ON.
