In the patch window the fixture numbers always would go 101 102 103 104 105 and so on now they are all jumbled until I patch them ? am I the only one that dose not care for this . why the change ?
This happened to me as well when i first used a showfile created in v 3.4 in the newer 3.5. When creating a new showfile in v3.5 it did't mess up my ID numbers. I assume it has something to do with using prior showfiles in v3.5. I ended up downgrading to 3.4 again.
Just a little SORT is missing... Remember if you recall the patch from views to restore the view if you did store it "unsorted" Was solved in the 3.5.1 patch when I saw it correct today.
