Bug Report - Intensity values snapping on Master Faders on 3.4 & 3.5.1
Hello,
I have a bug report, it's something we've noticed company wide and can't seem to figure out. Here's the hard to explain bug:
Intensity values on cues that are on master faders are snapping to their originally recorded values regardless of intensity values set by the fader when being set below their intensity values by a different cuelist. It's happening on both 3.4 and 3.5.1 software versions.
Here's how I came about this bug:
Let's take a small basic show with a room look and a video look. The bug presents itself when going from a room look set on faders (in persist on override) to a video look on a separate cuelist that bring intensity values to 0% or lower than what they were originally recorded at. Here's how I set up the console which brings out the bug - I take Fixture A @ 100% and record it to fader 10, hit play and set the fader to persist on override, clear the programmer. Let's say this is my stage wash fader. I decide that I want to run my stage wash at 50% for the show so I bring fader 10 down to 50%. The original recorded value is 100% for this cue, the fader is setting it to 50% in output. Now I take fixture A @ 0% and record it onto a separate "video" cuelist, it doesn't matter if this new cuelist is on a fader or not. When I activate the video cuelist, with Fixture A outputting at 50% from the stage wash fader 10, it then snaps to it's originally recorded 100% intensity value before fading to 0% from my video cue. It doesn't snap when releasing the video cuelist and going back to the fader 10 set value of 50% from 0%.
What that video cuelist is supposed to do is fade from 50% to 0% on Fixture A, instead it's snapping to it's originally recorded value of 100% before fading to 0%. I say originally recorded value because I've also tested recording fixture A at different values and it always snaps to it's originally recorded value regarless of what the fader is setting it to output.
This is a bug that seems to have presented itself in 3.4 and persists in 3.5.1.
Does this make sense? This is something we'd love to have fixed asap as a lot of us set up our shows this way. Thanks.
  • A coworker discovered that this bug can be unbugged temporarily by going into the options for the fader that the bug is affecting > check use htp > close the options window > reopen the options window > uncheck use htp > close the options window, replay the cue that the bug is affecting. This currently works to remove this bug as a temporary fix. However, if the cuelist/fader that the bug is affecting is released, the bug presents itself again. This temporary fix also works on multiple faders simultaneously.
  • I've also found with additional testing, that the intensity value snapping is snapping to the fader value of the video cuelist if the video cuelist is put on a fader, not the originally recorded value of the stage wash cue. If the video cuelist is not put on a fader it seems to be snapping to the originally recorded value of the stage wash. If I put the video cuelist on a fader, and have that fader at 100% it snaps to 100% and then fades to 0%. If I have the video cuelist fader at 0% it snaps to 0% without a fade time.
  • hello, Thank you for the report, we are currently working on the intensity snapping defect.
