So I'm currently building a coming up show on h4pc and I won't be at the load in where the rig needs to be flashed. I've decided to build lists and put them on command keys. My issue comes with trying to get the cue list I put in the command keys won't release. I've tried in the last cue using the macro release master. That doesn't work. Also when I try to add Release cuelist the command won't take.
Where did I go wrong?
