Time Only palette issue
Hi guys,
If I record a cue where the fixtures are referencing a Time Only palette, then I have an issue when breaking that palette reference.
For example, Fixtures 101 > 112, Position Time 5 Time 0 > 5. Record as Time Only palette. Record Cue.
If I now edit the Fade column of the cue list window, all Delay times default to 0s. This is not the case if I have applied fanned times without using a Time Only palette.
I would expect the palette reference to be broken of course, but if I'm only adjusting the Fade time, I would like to see the Delay times maintain their existing hard values.
What are your thoughts?
Cheers
Colin
