Hi guys,
Tested in v3.5.1.
If I apply an Effect Delay time to fixtures, I am seeing quite nasty results.
I applied fanned times to the Position Delay time, and copied the times to Effect Delay, but in playback the results are that the Effect immediately stops, then restarts as per the delay times and then settles to the final position. It's quite erratic!
Even without fanning the Effect Delay times, the same is still true if FX Delay time is not 0s.
Is this something that is already known?
