Full Boar and Hog PC
Can't tell if this is intended or not.
Repro:
CH: 2301 - VLX m1 - Note field: M1 Note
CH 2401 - VLX m2 (compound fixture) - Note field: M2 Note
1. 2401 "Change Type" to VLX M1
Creates 2301 Under M1 types.
Note says "Change Type of 2401" instead of M2 Note AND the original 2401 (M2 compound fix) is still in show.
2. Try it the other way:
2301 (m1) "Change Type" to VLX M2
Creates 2301 (same Fix number) under VLX M2 and keeps the same note field (as expected) and deletes 2301 under VLX M1 (as expected).
Is #1 expected behavior for changing type of compound fixtures?
