Display bug: palette name covers all columns in programmer
I have a show with several Int+Col palettes in which the name covers all the columns of a fixture in the programmer including the unit number. I can't seem to recreate this in a new show.
If the palette contains values for all of those parameter then it will be displayed like this when the show palettes button is enabled. You can turn off the show palettes button to see the values for each parameter.
Got this to occur in a new show. This is something that is not new to 3.6.0. This will occur when the sub intensity has a value and you are in compact mode for the programmer.
