Is there a way to use Batch to chg all List inside Batch 1 to time 6secs. I want to be able to chg all color cuelist to time 2 and then start tapping between colors. Then chg back to time zero and tap away with zero fade time between cues.
So if I have 30 list that I want to all of a sudden chg their fade times are you saying batch them all, add to fader, set fader to playback rate and set upper lower limit to get "0" sec to maybe "8" sec fades? I'm gonna have to try this in a bit. Sounds great, what if I don't wanna use up a fader. Any other options. Keystroke macro...just gonna take a while to write.
I use Batches to change my playback times regularly. I record all of my lists with 2 second fade times. Then I set my batch to be 0 at bottom, 4x at the top. Set the flash button to reset to 1x.
For you question about "faders"....I usually put all of my batches and tap syncs on their own page. Then I write a macro to jump to that page and a second macro to jump back to whatever page you want.
