I am upgrading all of our Hog4 PC today. I have encountered something new in 3.6.1 that I haven't seen before.
After install and trying to create a new show while connected to a network I get SHOW SERVER INT FAILURE. Once the cable has been pulled I can create a new show and launch while using the loopback settings. After I log off and reconnect the cable I relaunch the new show as expected.
The issue is that while connected to a network there is an inability to create a new show file. I have tested this on several machines with separate gear with the identical results. I rolled back one machine to 3.6 (1421) to test. There is no issue with that build and creating a new show file while connected to the network.
The machines are running static IP addresses, but this issue occurs wether set to any of the ip settings from the control panel options.
Has anybody encountered this? Is this a known issue?
Best
Josh
