Hi Marc, it was configured as an "multiuser" session with netnumber 1 for Hog4 for and netnumber 2 for Roadhog. Both were connected via an Swich, one cat 7 to the Stage, to on swich which connected to DP8K. The DP8k had a static IP adress and the netnumbers 2 and 3.
Moreover there was one Superwidget on one DP8k.
The Plotview have been closed all the Time, when i edited cues. The Roadhog was only a deskchannel console cause it was a TV record. I just wondered, cause all the time i tried to edit via "cue cue" i was able to count like 21..22..23..then it opened.
Same issue at home at WYG preprogramming, with only the RH4.
