Using the Hoglet and Hog4pc programming a pretty simple show with handles as IPCB's. Fader 1 and 2 have some how combined themselves as fader 1 is half the cue and fader 2 is the other half of the cue. The cue stack is only on fader 1. There is absolutely nothing on fader 2. I was worried that I had missed a few key strokes and some how miss recorded the cue. I then deleted every cue list I had and reprogrammed the fader 1. Only recording to it and not as an IPCB but a normal stack. Still having the same issue.
This is an interesting one. Can you confirm? 1) Cuelist is assigned to master 1 2) Master 1 is assigned to a normal fader 3) Nothing is on master 2 (empty) 4) Moving the fader on master 2 is affecting cuelist assigned to master 1
Can you describe how moving the fader on master 2 is affecting the cuelist assigned to master 1? Is it adjusting intensity, playback, or just mirroring whatever the fader assignment for master 1 is?
1) It is 2) Master 1 is assigned as an IPCB 3) Master 2 is completely empty 4) Correct, once Master 1 is at "full" the actual cue stack is only about 50%. So to bring Master 1 completely to a "Full" state Master 2 must be at Full
Master 2 is bringing Master 1 to a full fader position. So that the cue stack is at full. Without Master 2 the stack seems to be stuck around 50%.
I might add that I just installed the new software prior to doing the light programming that I am and didn't change any setting any where except the IPCB.
