Alright stay with me. We use a lot different types of RGB pixel tape. I used a generic profile for some. They are only 3 channels per pixel, but when I use the generic profile, it allows me to utilize what I assume is a hog related intensity on that fixture. The profile includes inverted CMY values (255>0) on each of the three channels. The profile allows me to utilize HS values. Essentially, it works just great. Now when I make a copy of that profile to utilize with a similar RGB fixture, that profile does not retain the intensity value. I can change IR, IG, or IB, but Intensity is missing.
If I simply patch the new fixture with the RGB LED profile, Everything works great, but I really like being able to separate my fixtures and create profiles for each of them. Is there a way to force the profile to have Intensity as an attribute like the RGB LED profile? Thanks
