When running Hog 4 v3.8.0 and below, only a select few touch screen monitors were supported.
If running Hog 4 v3.9.0 and above, then the touch screen needs to be supported by Windows 7 without any drivers. Fix/Solution I would like to suggest the below points while dealing with the touchscreen on HOG 4 OS. Make sure the touch screen is a supported make and model. This can be found in Chapter 3 in the manual on your console. Make sure you are running the latest software version.
