Programmer window's column size not recalling correctly 1st time on FullSize
I have found that when I have a view with the programmer window in the "small?" screen on the FullSize.. and then recall a view with the Programmer Window on one of the Main Console Screens... it recalls the view, but with all the columns stretched to about 3/4" wide.... if I hit the view button a second time (recall it again).. the programmer corrects itself the the correct column width (as stored in the view).
I wonder if this is linked to the console not recalling saved view settings for the cuelist window.. if you recall that view when there is no cuelist on the selected master?
D
