Id love to find a way to achieve this. There is actually DVI inside on the motherboard & vga but its disabled, you just get a hog 4 logo on the output & when plugged in it doesn't show up on the console as an available monitor. Clearly they disable it in software which is annoying. If anyone has ant insight I'd love an external touchscreen for the Gen 1....
The original Hedgehog will not output video. We have had many other models of Hedgehog that support video that you could probably acquire used. However, the latest Hedgehog 4X supports 2 monitor outputs, I would look into getting one of those if you feel like you need a Hedgehog with external screen capabilities. With a newer Hedgehog you would also get access to Hog-Net
