So I know you can color code cuelist the same way you can color code palettes. Is there a way inside the cuelist view to change the color of a single cue from white to a different color?
Yes, right-click on the header for the cuelist (where it says 'cue', 'comment', macro' etc and on the menu that appears click 'show colour' - it will add a column to the cuelist window, and you can colour the box in that column on a 'per-cue' basis ( it only colours the colour column though, not the whole cue row)
