If you go to adjust the FX speed inside a cue on fixtures that have a spread FX the output goes nuts.
So Select fixtures > touch > adjust speed.... The entire FX output flashes/pulses as you adjust the FX speed.
Making it impossible to adjust live! This needs fixing ASAP.
I knew it happened when adjusting spread, but this is terrible
