Wing/External monitor problems.
I have a full boar and a hog 4 playback wing. Wing is on the right. It was working fine before I moved it for another show a few weeks ago. However you had to move the mouse off to the left to get it over to the wing.
Now I’m trying to get the wing working correctly again. How do I know if it’s a version 1 or version 2 wing. It won’t display unless it’s on the bottom DVI.
I had it on the second DVI and tried to move a playback bar over to the wing and it won’t move. I can’t mouse over to the wing from the main desk.
I also tried to add another monitor so I can monitor DMX outputs and it won’t work on the top DVI.
 Now that I write this out it seems to be an issue with the top DVI....
