Font Size on External Monitor
How do I change the size of the font, buttons, and everything on an external display? I just upgraded to OS 3.9 and the font size on our external monitor is really small, whereas it wasn't before the upgrade.
  • Lot of changes in the new 3.9 release regarding graphics. Maybe in prior versions your monitor was not driven in full resolution. You might use a scaled smaller resolution.
  • Thanks for the suggestion, but that didn't help. It did make the windows a bit bigger, but the font size stayed just as small and the monitor looked blurry. Even with a restart, the problem still happens. And, I had to restart after changing back to the old resolution to get it to work right. Any other suggestions?
  • I had to go to 800x600 with my ELO 1919L monitor to get it even usable.
  • I'm experiencing something like this on my Rackhog. I have it connected to a very crappy Raloy rackmount monitor/keyboard. I suspect that this is due to bad or missing EDID data during bootup and X11 (or Qt) is making the wrong decision about display properties.
  • You might try running the monitor as a hog3 wing and see if the helps you.
    We’ve done that since version 1 of the hog4 for our elo
