Cue Only bugs?
Two potential issues that I experienced with a Cue Only cuelist today.
  • With a series of cues with fixed Wait times; The list would, intermittently, release. The active cue would still progress as expected, but in a released state. Marking the list as Persist on Override appears to be an effective workaround.
  • In the same series of cues; if a cue had a fade time longer the wait time of the next cue, being cue only, the levels in cue 2 would return default values [null in the cuelist] at the moment the next cue was taken. Not, as I would have expected, at the completion of the fade. In this case the cuelist had a release time of 0. I was not able to experiment if changing the release time affected the situation.
