Simon LX said: If you always start at the first cue of each set of looks, just make the first cue a block cue - select all fixtures, touch, then record the cue. This will stop tracked information. Not sure what you want to happen if you Goto your 'blank' cue?I don't want to do that because it will take latest priority over that fixture and bring it to 0% intensity in the blank cue and all subsequent cues. This will cause me to be unable to run scenes with this fixture in them at the same time as the cuelist because everytime I press go on the list it will bring the fixture back to 0% and I can't use "HTP" or "Priority Levels" to resolve this with the way I intend to use the cuelist. The "blank" cue is intended to be a cue I can jump to between sets of cues with the GoTo key without taking control of any fixtures
