It gives a way to access shortcuts on the chosen master. Example: If there are wings setup and you need to control the playback rate, and the fader is set up as an intensity fader, instead of having to reach to that fader hold Choose and spin the encoder wheel you can hold the choose key above assert and achieve the same result.
