I am having trouble starting HogPC when double clicking the icon either nothing happens or eventually there is an windows error boost::interprocess_exception::library_error
Then the Hog PC error screen pops up giving you the option to Kill the application.
Observing in task manager the memory allocation runs up to 100% then drops back down to normal in - Service Host: Local Service (Network Restricted) - then the Hog4 Launcher app may briefly run then disappear.
I started to turn things off that were running under this service and eventually found that turning off the Windows Event Log enabled me to start HogPC every time.
Not being a Windows expert I do not know if this will cause me more problems down the line.
Any thoughts?
Seb
