I was trying to make a keystroke macro that would switch the highlight palette on and off so that highlight would only affect intensity and nothing else but have the ability to quickly switch back and forth between highlights normal action and this modified one. It was simple to start recording this macro by telling it to open up an intensity directory and then I right clicked on the palette and in the menu select the "set as highlight palette" button and then close the window. When I then went to playback the macro the right click menu did not come up but the other clicks around it did and it seems that the palette gets clicked but the menu is not opened. I am not sure if this is just a limitation of the keystroke macro or if this is a bug in the software. I am running Hog 4 PC on software version 3.13.
