Custom Screen Saver
If I use a custom screen saver and then use the lock the screen when I try to unlock the desktop again the screen lock doesn't appear and the custom screensaver is fronted ?
Is that the correct behavior or should the actual screen lock become visible again?
The screenlock is active and works but isn't visible.
Fullboar using sw 3.13.0
