Having issues today with midi notes not being processed after a second server joins the session. Both consoles (on current release s/w) are set to the same net numbers, and both have internal DP’s set to the same net numbers. Consoles on separate IP addresses. Main console only receives and precesses incoming midi notes when the second console is not logged in and is offline. I don’t remember this ever being an issue in the past.
It is best to not have DPs with duplicate numbers on a network. Possibly try changing the DP Net Number on the second console to 2. The patch from DP1 can then be cloned to DP2 if needed as a backup for example. As a test possibly change the second console to Net Number 2 as well and see if there is any difference.
Hi Mitch further testing this today and I can confirm that if the second console internal DP has a different net number then the midi operates as it always used to. Yes the DP can be cloned across but it feels like an unnecessary work around and on this style of show where we are constantly patching will surely lead to confusion with the crew.
