[question] Learn timecode hits
Hey guys,
I'm currently working on a timecode show with a lot of lighting hits to the beat of the tracks. I have a separate cuelist that is designated to trigger my blinders for a split second when I hit go.
Is it possible for the console to learn the timecode timing every time I hit go for that cuelist (instead of just the first time)? The only way I currently know of doing this is to copy the cues in the cuelist as many times as I think I'll need, and learn timing on the resulting stack of cues. This is obtuse, because it means if I need to make an programming edit to a hit, I will need to edit each copied hit cue.
  • Make a new cuelist with as many empty cues as you think you'll need hits for. Then use a comment macro in every cue to run your blinder cuelist. Learn timing on your new cuelist.
