This makes me so very angry that in 3.14, I could not figure out why my output window was not showing any cue information. Then I figured this stupid ETC lock was a big part of 3.14. What if I want to just work on a show without a widget hooked up, am I supposed to carry a DP8000 on an airplane if I need to program multiple universes? Grand Ma is looking better every day
This had been by the way like ever... Output window data is feedback from the processor. So if no processor is found no output data, eg. if in older version you have patched to an external DP and this wasnt present you also dont get data or cue-feedback etc. Adding visualizer stream might also be an option (did not try) as this should also activate the DP
