Hi All,
I currently program for a multi-campus church, sending one single file that contains information for all three systems. Will version 3.14 require the widgets at each location be configured every time when loading the show?
Programming is done on Hog4 PC with a Hoglet 4. One campus has a Superwidget and the other two have single universe widgets.
Previously this has not been a concern since the widget mapping was local to the console/PC. I'm not sure about updating to 3.14 since it may cause the need for extra setup when loading the show file on each PC. If operators will need to go into the show file and modify the mapping each time they load the file, this version is no good to me. If the single universe widgets both default to Universe 1/A this is also no good to me either.
Other lighting software manufacturers keep the mapping attached to the processors/output devices and NOT with the show file.
Do I need to purchase 3 HPU's to get around this issue? :|
