3.14.0 RH4
I have a 10 step cuelist, and I am currently in cue 10.
I use the syntax MERGE CUE ENTER to merge the programmer contents into the current cue on the chosen master.
The operation works, but the Command line says Cue 11 merged.
That’s incorrect as it merged into cue 10 (there is no cue 11).
I didn’t have a chance to check if it would have said Cue 11 even if I was on Cue 9, or 8, etc.
please confirm you can repro or I can send the showfile over....
dan
dan
