HPU dp8k-linux-golden
Just testing out and building a template show on my HPU. I have 3 universes of regular lights patched in, 2 universes of RGB leds, and 16 universes of RGBW leds patched. There are only 3 universes of data outputting through the 5 pin DMX ports, everything else is sACN/ArtNet. I noticed the dp8k-linux-golden CPU process was running at 106% with blips up to 109%. All other processes are running at between 1% to 9%. Should I be concerned if I load up all 64 universes on an HPU? Does it start to slow down data processing past this point?
Bryan
