Hi Everyone, we just switch over to 3.17 on our show from 3.16.1, and we're experiencing a regular backup issue every time we try to run a local backup. The error Code reads:
"Attic State Mismatch in table view items. Suggest a log-off and retry.
Missing Cross References between tables.
Show backup failed."
We are able to run a backup after a server log off and log on. But this does make it a bit difficult to run periodic backups throughout the day.
Rig hardware:
HPU as primary server.
RH4 and Full Boar as Failover/programmer desk (server and DP on).
Hoglet with Hog4PC as a tech desk (Server and DP off).
Backup fails on all systems until there is a Primary server log off and log on.
My team has also tested this and experienced the issue on other stages on the show, with similar hardware setups.
The only thing we haven't tested is if a fresh showfile started with 3.17 has the issue, all of our current shooflies were started with 3.16.1.
-Elton
