Bug? Copy replace list doesn’t work as expected
Hello,
I would like to copy replace (either with the soft button or dialog) a cue list to (replace) another cue list. It looks like Hog is executing the command (if I do not use the soft button, the dialog appears with insert, merge, replace, cancel) without any error or red text in the command line, but the cue list is not replaced at all. The cue’s aren’t changed, just the same as they where before replacing the list.
When using ‘merge’ it is merging the cue’s from the first list to the other list, but I need to replace the list in total.
Hopefully this will be possible.
Regards,
Maarten
Hog4 v 3.17.0
