So this might be a weird bug or may be intentional?
I'm trying to write macros for some stuff and it's not working the way I think it should. So I tried doing it from the command line and it's doing the same thing.
I'm trying to copy a color palette to another one via merge.
If I touch a palette on screen, hit merge (physical console button) and then touch another palette it works perfectly.
However, if I type it in via key presses it doesn't. I type (all physical console buttons)
"Colour" 1 "Merge" "Colour" 50 "Enter"
It creates the palette but doesn't copy the info over.
Additionally, if I type
"Colour" 1 "Copy" (select merge softkey) "Colour" 50 "Enter"
It works fine.
The softkey thing isn't THAT big of an issue, except the softkeys 13-16 don't work via macros on the roadhog. At least as far as I can tell. Since those 4 are on a 2nd page.
Any advice for this?
