...try to use etcher like always to create my restore flash drive, but today: "balenaEtcher needs privileged access in order to flash disks. type your password to allow this."
...no idea, which password, never had this problem !
Im using version 1.7.9 on a PC and i don't see this message?
If you are usign a PC maybe right click on the shortcut and run as adminstrator or uninstall/reinstall and see if that helps?
Good Luck
...using Mac OS...
Hello,
I'm using version 1.7.9 on a PC and i don't get his message.
Maybe uninstall and re-install, sometimes i get hese administrator requests and i right click on the Balena etcher shortcut and run as administrator.
Best C
...i´ve tried all....no idea...same procedure like always...
Solution: password is the standard mac login password
