Hi all,
i bought an elo ET2243L as an external screen for my full boar 4. but it doesn't work.
Does anyone have a solution for this?
What does not work? Video? Touch? Have you tried both outputs on the back of the console? does it work in 1 and not the other?
Hey Gabbi,
I found te problem, the ELO touch is not working but i take a other type ELO screen and thats working.
But when i trying that i found a other problem and that is there is an output not working (dvi-d 1) the other output is working.
There is a known issue with output 1 on Full Boar 4, Output 1 on Full Boar 4 is active so some monitors do not work with it. So far we only know of 2 but it appears you may have a 3rd
The monitor should work in output 2 but not output 1 if you are experiencing the issue
Thats right its work in output 2.
