Couple weeks ago with a new laptop that had pre installed windows 11 I was trying to build a fixture. In the build I was testing to see if it created the right values the hog desktop crashed when I touched the strobe wheel on the virtual hog wing. Restarted the hog application and then all worked again.
Now this weekend, I had 2 Robe Spiider up and running, recording some palettes Later when I patched in a Cameo Zenith W600 SMD and touched the intensity the desktop crashed. Can’t tell if had the patch window opened in the secon case.
