Time Pallets incorrect behavior
Time Only pallets they seem to behave different from other pallets.
For Example, I made a Time Only pallet with value of 1s/1s fade time stored under the Intensity Directory whilest making shure to use the correct masking.
Next step is to record a Cue using the Time Only pallet as source for the fade and delay times.
So far so good!  So i made some more cues this way and playing back the List works as intended.
Now when i change the Time Only pallet, to for example 2s/0s, and playing back the List, the lights only show the new Fade In time but still the old Fade Out time of 1s. I Open the Cue to check the content, but it shows correctly the used Time Pallet and the new time of 2s/0s.
Looking at the Fade time that is showing in the list behind the same cue it states 2s/0s, 1s...
Any ideas as of why this is happening, A bug perhaps?
