Front Palette Window when Kind Pressed not working for Group
v3.19.1 (3500)
I have just updated to v3.19.1 and the Front Re-Selected Windows, aka 'Front Palette Window when Kind Pressed' no longer works for the Group button. You have to re-open the Group window every time you need it using the double press action with the accociated opening animation effect, and if you use Views then you end up with multiple Group windows open. This is very irritating.
This has always worked okay previously.
