There seems to be differences in the Fixture Names from the Library (with it's summary XML file) / online fixture search, and what is displayed in the Hog4 Software.
It tends to be down to different letters or words being capitalised.
e.g. fixture name="Scenius Unico Standard"
is Scenius UNICO standard in Hog 4
I assume it's because Hog4 is built on Linux which is case sensitive?
This is problematic if you're building an XML Patch File externally to import, as importing it will drop any fixtures that don't have the exact capital letters Hog4 is expecting.
There must be another name field that is used by the Hog4 Software when uses the library files.
Is there a way to make these match going forward? or drop the need for Case Matching on import?
