I would love it if somebody could provide me with a checklist or workflow to diagnose this problem. Software and hardware please.
much thanks in advance
Things to test:
If the issue is still not resolved, you may need to replace your display. Depending on what display your console has affects whether the console needs to come in for the new displays to be installed, or if the displays may be replaced in the field.
For further info on replacing Full Boar 4 displays, check out the article below.
https://support.etcconnect.com/HES/Consoles/Hog_4/Hardware/Replacing_the_displays_on_a_Full_Boar_4
Very much obliged.
The problem was with the grounding cable on the touchscreen bimba. The pole had worked loose from the connector. I can’t imagine how that could have happened on its own.
