Today working on a prep showfile. It looks like that the Lustr+ direct mode is not working correctly with colorpicker.
In the colorpicker it's only controlling the RGB channels all the other color parameter get ignored. This is true for all the colorpicker functions...
The only way the get the correct colour is to use the Physical parameters.
Exemple:
From no lists active (Pig Release) select the fixture and choose a colour in the colorpicker or gel section. only the RGB channels are changing all the other stay on 100% as that is the default values. If you choose an other color again only the RGB channels will change. At the moment I only see this happening on these fixtures.
System:
HOG 4 Running v4.0.0.0
Capture training file on windows system
Kind Regards,
EJ Berendsen
