Server is up, work lights are on. This is all turned on from the server, a RackHog. Now, I then join the show with my computer or a console, and any cue that was 'Up' immediately resets/turns off. Unsure what is going on here.
In 3.20.0 there is an issue where Playbacks snap to BO when the virtual wing window is opened and then there's a second where when Hog 4 PC joins a show it takes all faders to 0. Do you think you are running into their of these or a new issue? Both are currently in beta for 3.21.0 and the Virtual Wing Window issue is resolved in 4.0.0.
4.0.0 is the big color overhaul where you would need to start a new show as 3.X shows do not transfer to 4.0.
This is definitely the issue. Thank you for the reply.
