Hello,
Hog OS 4.0
I have change a lustr x8 in expanded mode to Lustr x8 in direct, and the color picker and gel picker is only working on RGB colors.
Hello,
Hog OS 4.0
Hello, we have narrow this issue down to Cal bypass being enabled on the X8 in expanded mode. If a fixture has cal bypass enabled when change typed only RGB emitters on the change typed fixture will work. To work around this please disable cal bypass in the fixture window and then change type
You can change type back to the X8 expanded, disable cal bypass, and then change type back to the X8 direct, and you should be functioning as expected
