After the update was released, I moved the show from version 3.21.0 to 4.1.0. On the first day everything was fine, the scenes played correctly, but the next day all the scenes began to stick, that is, they turned on and off immediately
Hello,
Did your Scene preferences get changed to "Auto-release at end" under the Playback Options?
Can you provide us with the 3.21.0 and 4.1.0 show file as well as the 3.21.0 XML so that we can look into this issue if that was not the case
Thank you!
