Out of nowhere hog won’t stay connected to capture I’m running them on the same pc. Hog on pc finds it but doesn’t stay connected soon as I hit apply and exit it goes back to being unconnected
Hello,
Are you using the Hog Connectivity or the CITP Option in the visualizer stream?
Before you press apply make sure the Protocol is correct even if you've auto discovered using the dropdown
