v4.1 Clay Paky Stormy CC extended color mixing does not work after show import from 3.21
v4.1 Clay Paky Stormy CC extended color mixing does not work after show import from 3.21. They are just controllable via physical RGBW, all the virtual stuff does not work at all. Noticed that other color mixing fixtures have the same behavior but when moving the physical sliders once the virtual mixing works perfectly. This is not the case with the Stormy CCs
  • Yes. :-( I tinkered a bit further with the system and I think it has something to do with the fixture profile. At v3.xx the hardware intensity channel of the 15ch mode was set as a (2nd) strobe parameter for I do not know why and intensity was done via RGBW virtual intensity but the hardware intensity channel (2nd strobe parameter) was blocked somehow, so no output occurred. I had to fix this fixture profile with switching 2nd stobe parameter to intensity and uncheck every virtual intensity. This corrected "user profile" got then transitioned from 3.21 to 4.1 with the show. That might has fucked up the colors. But when i add the latest library fixture profile on 4.1, the hardware intensity does not work as well, though colors seems to be fine yet, according to the output window. Guess the bug in HSE library fixture file transition somehow from 3.21 library to 4.1 library although under 4.1 there is an intensity parameter controlling the hardware intensity. So my previous "v3.xx" fix does not work anymore. :-(
  • This issue should be resolved in v4.2.0. We have a beta build of this version available. If your interested and available for beta testing please reach out via direct message or email
