Trying to Export my patch to upgrade to 4.1, but can not find the Export Patch. Showfile seems to be corrupted as I can not Export Show.
You need to export your whole show not the patch. It’s in the show manger window. There is a soft key ‘export show’ underneath backup soft key.
Setup - Shows - Export show
Show won’t export, I fear the file has been corrupted to some degree preventing the export.
Try merging the contents of your old show into a fresh new show file and starting the export again from there.
Just tried, server failure. I feel like this may be a lost cause. The file I’m trying to merge was created on a wholehog, can that be effected this in some way?
